Best option is to do wheels and tires with the hose
Faster, more through and you can still do rinseless or waterless on the rest of the car
I did a waterless wash and used Megs Wheel Brightener (10:1)
Dwell
Agitate
Rinse by spraying heavily with waterless was solution
Dry with MF
Spray with waterless solution again to make sure the MWB is diluted/neutralized
Is anyone using the Hyde's Rust Stopper?
Could have used it on these big GT-R discs
Every car we do gets that rust. We usually just pull it forward a little and the rust it gone (just to make it look nicer when the customer sees it). I think, but don't know, that the rust is probable just the metallic dust on the disks. Either way, it's no big deal.
I agree it happens to varying degrees anytime you get the discs wet.
Wheel Brightener seems to exacerbate the rust.
This waterless was was done without access to the keys.
I do hate the idea of then rust landing on the wheel/rim the 1st time they hit the brakes
Is anyone currently using the Hyde's Serum Rust Stopper? How many oz per car?
The problem with the rust is - yes it's easy to get rid of. However, little rust flakes will fly off onto your newly clean wheel make it less than perfectly clean if your picky like me.
I'm thinking of trying Hyde's.
I use the same products/methods as I do for the other vehicle surfaces, with the exception of the type of towels used for the tires and the inner wheel barrels:How do you guy handles cleaning wheels and tires if you are doing a waterless wash?
This is almost exactly what I do. After doing a rinseless wash on the car using 2 buckets, I'd still have about 1.5 gallons of clean ONR wash solution left.I have not tried this method yet but I will in the future. Spray the wheel and tire with Optimum Power Clean (safe on all surfaces). Scrub the tire with a brush and clean the wheel with a black microfiber towel. Then rinse the wheel and tire with diluted ONR in a spray bottle and wipe the wheel dry with a new clean black microfiber towel. The tire can dry on it's own while cleaning the other wheels
Mothers Back To Black tire renew is really good for tires. I use Tuf Shine normally, but I've used the Mothers and I'm really considering switching to it. Spray it on and wipe off no water needed. I can't comment on how well it cleans compared to TS. But I will say it cleans better than any APC I've ever used on a tire.
