Perhaps defining what we mean by "protection" is a good place to start.... the whole idea of "if it beads... if it sheets... there is protection" may or may not be true depending on what qualifies as protection.
Clear coat provides protection to the base coat, I think we can all agree on that (maybe?), but most everyone believes that if clear coat does not bead water there is "no protection on it". A bare clear bra provides protection to the clear coat, but a clear bra does not necessarily repel water (though many do). Therefore, why is beading associated with "protection". Protection is quite a broad term when you start to think about it. I believe it is simply because for as long as we can remember, applying wax has created nice water beads. Once the beads are gone, we apply more wax and it beads again, thus providing the illusion that the presence of hydrophobic properties mean a wax (or sealant or coating) is still there.
My questions is this: is water beading all that defines whether or not a wax (or sealant or coating) is still present? Does it even play a factor in whether or not a product is still there? or have we all been brainwashed after so many years?
I honestly do not know the answer because I do not have the ability to perform the necessary tests to determine if a substance so incredibly thin has fully been removed from a surface.
It has been my belief that the phenomenon of water beading/sheeting is simply a product of high surface tension.
Surface tension can be altered by a variety of cleaners (surfactants)... in fact that is, by definition, the purpose of a surfactant.
A soap (or degreaser, etc.) cannot work well if it simply beads up and is not able to cling to the surface, therefore many (most? all?) cleaning products contain surfactants to help reduce surface tension and allow the cleaner to properly wet the surface which it has been applied to in order for it to do its job of cleaning said surface. I am no chemist, not by a long shot, but it does not seem like a far stretch to assume that harsh cleaners, or even repetitive use of gentle cleaners, can have a permanent effect on the surface tension of whatever surface they are cleaning (ie your waxed, sealed, or coated vehicle). Likewise, I don't feel like it is hard to believe that substances that get on your vehicle while driving will have an effect on surface tension (especially the crud they put all over the roads during the winter months). This is pretty evident when, at least on my vehicles, the areas that get covered most heavily by road grime, salt, etc. are the first areas to stop beading.
Now, a lot of people believe that when a vehicle or a specific area on a vehicle stops beading the "protection" has been removed. I'm not fully on board with this train of thought. In my head, now I am specifically thinking about a coated vehicle at this point which I know is not the topic of this particular thread, if a coating were to be removed entirely, there must be some sort of abrasive present. If there was some sort of abrasive present, a car that is not properly waxed, sealed, or coated would eventually have clear coat failure in these areas. I have not personally seen a vehicle with failing clear coat on the lower door panels... from what I have seen, most clear coat damage is found on the horizontal panels (hood, roof, trunk).
These reasons alone are enough to make me skeptical that water beading is that closely related to the presence of a wax, sealant, or nanocoating.
Are hydrophobic properties important/beneficial? Absolutely! No doubt about it... but I don't think it is the only sign that a wax, sealant, or coating is or is not present.
..... am I off base here? or does someone else out there follow me?
