Wax process O.K ?
foneguy
Just received my BOGO of the pinnacle Sov paste wax (great deal),
and I have a quick question on my wax process.
Once I am ready to wax, I assume it is O.K to apply using the included foam applicator. But can I remove it using my PC with the microfiber bonnet ?
This is my first time using this wax and I just wanted to be sure I was doing it right.
I usually hand apply, PC off, and then walk around with a supreme 530 checking for any missed spots or needs for extra attention.
Any help is greatly appreciated....Thanks!!!!Feed back please
Sounds good to me, you can you a QD to give it a bit more pop if you wish after you have removed to wax, no resting time though
Just remember that souveran is a wipe on wipe off wax. There is no need to let it haze. I find it so easy and actually enjoyable to do it by hand. Just apply to one panel at a time and remove once you have completely covered the panel.
Thanks alot I just wanted to be sure......I will try the foam app ON and the supreme 530 OFF......
Thanks Again !!!
Foneguy,
You should be set, like you I bought the BOGO and used the foam applicator. I liked it better than the MF pad I was using before. Also the 530 is awesome at removing the wax!
I wax a panel, take a sip of a nice cool refreshing beverage and then wipe off with a MF towel.
just remember light coating, nothing thick needed. You should be able to get 30-50 applications from a jar of Souveran. WOWO -- wipe on, wipe off panel by panel while still lightly damp.
Thanks everyone !!!!! always great info...
I will use foam app - on , sip cool refreshing beverage ....supreme 530 off while still damp, and then sip again, and again...
