Scubadaddy
- Jun 14, 2013
- 24
Spring is here! As soon as the temperature allows, I plan on adding some Wolfgang sealant to my vehicle. I applied it in late fall before all the snow.
Question #1: Since I do not plan on doing any correction, do I need to remove the sealant or just clay and apply over the coat on now? I understand that you should remove a wax/sealant if you are using a different wax/sealant, but do you need to do this if you will be using the same one?
I have some Wolfgang finishing glaze. Would this:
1. Remove the sealant?
2. Should I apply it even though I am happy with the paint's condition. Does not need correction. Would this increase the shine/gloss? Is it needed?
Thanks!
Thanks!
