You can maintain with Collinite itself using 520. I won't link to the Collinite page itself but check what it does/doesn't do on their page and you might have exactly what you need:Winter months unfortunately I goto touchless car washes.
I coat the vehicle with collinite 476. If I use a spray wash like megs quuxk wax will it scratch the paint?
After 20+ winters using touchless car washes in Alaska I have never seen one that got a car clean enough for me to even consider wiping anything on or off immediately after the wash, much less after driving home following the wash
If I can't garage wash in the winter I depend on the base layer I applied before the weather got bad
Alaska only uses enough salt mixed into the mountains of road sanding dirt to keep the mounds from freezing but we still get a film on our cars that no drive through wash will touch
Your mileage may vary and this is another "place to place" variable that a simple answer doesn't address
I completely agree.
They are good to get the heavy stuff off, but the road film is still there.
1) I would find out what the pH of the soap is that the touchless car wash uses. A lot of these touchless washes use soaps with very high pH to compensate for the lowered cleaning ability of not making contact with the paint. If used, the high pH soap could degrade your Collinite wax.
