And then to confuse things even more, have a look at Duragloss products such as DG # 111
Duragloss Clear Coat Polish (CCP) #111 #111 is actually a polymer paint sealant and not what most of the detailing world would consider a polish at all. Duragloss uses the term "polish" pretty loosely in the marketing of their products. I think this confuses a lot of people.
Now have a look at Meguiar's Mirror Glaze # 205 Ultra Finishing Polish.
Meguiars Mirror Glaze #205 Ultra Finishing Polish, final polish, Meguiars polishes, car polish, 205 FP
This product is a polish in the regard that it will abrasively remove light paint imperfections such as minor to moderate swirls, buffer marks from compounding or can be used to simply gloss up a paint finish that needs a little extra POP. This product contains zero protective materials such as wax or polymer sealants and needs to be followed with such a protective product.
Then you have the non abrasive, "chemical polishes" such as Poorboy's World Pro Polish original formula
Poorboy's World Professional Polish 32 oz., Poorboy's Car Polish, auto polish (Pro Polish 2 contains strong cleaners
and non-diminishing abrasives) Pro Polish (original formula) is a non abrasive chemical polish that is actually quite "aggressive". See... there is a difference between the terms "abrasive" and "aggressive" Pro Polish contains very little (if any) abrasives, but is quite aggressive chemically.
The chemicals in Pro Polish can chemically soften and remove layers of paint when used while machine polishing. This polish needs to be followed by a wax or polymer sealant. When removing hard water mineral deposits, nothing beats Poorboy's World Pro Polish, except for maybe Pro Polish 2 if you're dealing with extreme amounts of mineral deposits. Both Pro Polish original formula and Pro Polish 2 are quite capable of removing severe paint defects, depending upon the machine and pads used.
Then you have your AIO, or All In One type polishes that contain a means of both removing paint defects and leaving behind a protective product. An AIO can be non abrasive such as the following products.
Poorboy’s Polish with Carnauba (BLUE): A Quality Poorboy Polish & Protectant For Dark Paints! poorboys blue polish, dark polish, car polish, clear
Poorboy's Polish with 100% Carnauba: Clean and protect in one simple step with Poorboys carnauba polish! finishing polish, poorboys carnauba glaze
32 oz. Poorboys World Polish with Sealant, Poorboy's Polish & Sealant, PB PWS
Then you have abrasive AIO products such as these.
Meguiars D151 Paint Reconditioning Cream
Duragloss Marine RV Polish #501 cleans, polishes, and shines gelcoat fiberglass boat and RV finishes. Duragloss durable boat and RV polishes.
Optimum Poli Seal, paint sealant, optimum detailing products
These are just a few of the AIO products on the market. There are many to choose from. So many in fact, and many using different terms such as cleaner wax, cleaner sealants, polish etc. that it can really be confusing.
In the end, it is always best to read the product description and/or post a question about a specific product or give the manufacturer or AutoGeek a call to be sure you know what it should be used for before ordering it.
I hope this helps you more than just confusing you even more. TD
