Wax wheels?
Zalmon
My 2016 Rogue has painted wheels. Should I wax them after cleaning?
I would suggest the hydro blue as well but wax is better than nothing.
Car Pro's Dlux is coating for your wheels that will keep your wheels cleaner much longer than wax.
McKee's hydro blue for ease of use. Coat them for better protection and easier cleaning, its a fair bit of work but you do it once and you're set for a long time. Wax is a waste of time given the effort vs. reward proposition. I wouldn't even bother with a sealant if you have to wipe it on and buff it off. The McKee's is a sealant that won't last anywhere near the time a coating will, but its so easy to use that you can do it as often as necessary. I haven't tried it, so I don't know whether it makes the wheels as easy to clean as coated wheels.
