Prima Banana Gloss. Super easy on and off as an added bonus should u be looking for that kind of product.
And just to add....
My guess would be any true hard wax if applied to a polished surface and allowed to fully dry before removing would fill the best.
NXT Tech Wax was in part formulated to fill well. It's not a wax but a sealant.
Have you done a comparison between the NXT and Turtle Wax to see which fills better. Won't buy anything until I hear which fills better.
I am going to use whatever product fills the best when I will be doing a concourse show event in the near future.
Why not use a dedicated glaze, and then a wax on top?
Poorboy's Natty Blue seems to fill very nicely...as does 3M Perfect-It Show Car Wax.
I'd go with Poorboy's though. MUCH easier to apply and remove.
Have you tried Turtle wax as a comparison?
Applied via machine will give more even coverage, and really work the glaze into the swirls/scratches. Personally, have used a red pad and 3" polisher with great results.
Here's a Grand National I did a few months ago with Black Hole and Natty's Blue. Came out great, with the above application method.
There were some swirls that weren't filled/covered...but still looked killer.
If I am using a machine to apply the glaze, aren't I polishing? The paint is very thin and I don't want to get down to the primer, so this is the reason for looking for a product that will fill.
There were some swirls that weren't filled/covered...but still looked killer.If I am using a machine to apply the glaze, aren't I polishing? The paint is very thin and I don't want to get down to the primer, so this is the reason for looking for a product that will fill.
No.
Applying a non-abrasive is not "polishing".
