Saw a vid where a guy did this. Bad for plastic? Would it simply attract more dust?
Shoot...that’s nothing.Saw a vid where a guy did this.
Not to mention if you spray it directly on the wheels. You are going to get wd40 on the brakes too. If you get Wd40 on the tires it will start breaking Down the rubber.
Why, just why?
Thanks for the attempt at clarification;I think he means wheel WELLS guys.
Just spelled incorrectly in the title....
...the greater majority of
wheel-wells/wheel-well areas:
Again, IMO:I have seen it done before and it
works OK but it attracts a lot of
dirt/dust/grime.
Speaking of clarification:Better off going with hyper dressing,
VRP/VRT etc.
however, I knew exactly what he meant.
LOLZ!I've been lurking here for a while and have seen a ton of your posts. I have to say they come off just as pompous when it is directed at me as when I read them in the past.
My brain was going a lot faster than I was typing but I intended to write he should use an APC for cleaning and those products above for dressing.
Cheers
Yes, did mean wheel wells but also discovered mine are felt lined. Wonder what the point of using felt is? Thanks for all the replies everyone.
