Have you gotten one of those "extractor-shaped" attachments for it?
Yeah, I'm talking about one of these:
Shop-Vac Claw Utility Nozzle for 1 -1/4 inch Hoses
IME shop vacs usually don't come with an attachment like that in the box.
just try to look up the meaningful specs like water lift and CFM and base your decision off that.
Be careful of shopping horsepower ratings--they don't mean much in consumer line vacuums anymore. A 1hp Dayton will outperform a 5hp consumer edition Shop Vac. Not to say the consumer versions won't fill your needs, just try to look up the meaningful specs like water lift and CFM and base your decision off that.
Probably, somewhere. It doesn't feel like it has enough suction though in general to lift much regardless of the attachment. Yes I did clean the filters. Hah.
I do understand horsepower to a certain extent. It's like wattage. Wattage indicates how much power something uses, not how much power it puts out. People still have trouble grasping the concept of the new light bulbs compared to the old.
I was looking at this:
Vacmaster VBV1210 Detachable Blower Wet/Dry Vacuum, 12 Gallon, 5 Peak HP
Unfortunately, I can't seem to find any actual specs on it but the reviews say it really sucks.
EDIT: Found specs on another site. It looks to come in at 133CFM. I don't see anything about "water lift" unless that's another term for CFM.
I have a 2 hp Shop Vac that I have been using to clean my house carpeting, and it isn't enough. I use the crevice tool to concentrate the suction and it still isn't enough. You can hear the water gurgling up the hose, but the removal is not fast enough.
I was considering the 6.5 hp Shop Vac in stainless to replace it, even though what I really need is an extractor, but that is a $1500 tool. Extractors have between 102 and 137 inches of lift, from what I have read.
You don't need to spend a ton unless you want too on a vacuum. Here's what I have and its 60 bucks without some add ons .RIDGID, 9-Gal. Wet/Dry Vac, WD0970 at The Home Depot - Mobile
The reviews speak for themselves, And I'm here to tell you this vacuum performs. I have the detailing kit, but in the future going to upgrade that hose to the yellow 25' flex/ non kink non bend hose. Worth a look.
