I've got some scuff marks on my clear bra from hitting a concrete pole base. Do you think that this can be wetsanded and polished with M105? Has anybody wetsanded clear bra?
Thanks!
Thanks for all the responses guys! I guess I'll stay away from wetsanding my clear bra!
That's great!
{May I also suggest to stay away from concrete pole bases.} J/K
test a spot with aciatone wet it frist then try the aciatone and wash off fastI've got some scuff marks on my clear bra from hitting a concrete pole base. Do you think that this can be wetsanded and polished with M105? Has anybody wetsanded clear bra?
Thanks!
Or even rubbing alcohol. I was told to try it as a last resort if a scrape or scratch won't come out. I think it softens or borderline melts the bra a bit.test a spot with aciatone wet it frist then try the aciatone and wash off fast
I have wet sanded and polished a 3M clear bra back to new. Used 3M 2000 grit and sanded by hand with soapy water. Followed with Flex 3401 and PC7424 orange pad and some 3M scratch X, then Wolfgangs 3.0 swirl remover, and then Wolfgangs finishing glaze, followed by your favorite wax.
Quick Edit, see what you can get of with a Mr Clean Magic Eraser 1st.
