I just had my 09 Infiniti FX in black repainted a few weeks ago. It has a ceramic clear coat from PPG per manufactures recommended refinishing products.
Anyways the paint job came out flawless. But even though the body shop paints good they don't wetsand very good. There is no orange peel in the clear but there is a lot of wet sanding marks that weren't removed.
They left a whole bunch of rotary buffer swirls and hazing in the paint. So I took out my PC 7424xp equipped with a yellow LC pad and Meguiars M105 on speed 5 and it removed ALL the rotary buffer swirls and hazing. But now im seeing these RIDS in the finish everywhere now that the finish is clear. They are in straight lines like swipe marks and from what I see these are wet sanding marks that weren't removed too well.
What should I do?? Do you think the bodyshop wet sanded the paint and just went straight to polishing without stepping up to a finer grit wetsand paper? I only have a PC buffer so I can't use a more powerful rotary to fix this. I was thinking about wet sanding those areas with like 3000-3500 grit wetsand paper then stepping up to a stronger pad like a surbuf pad or should I just continue using the LC yellow pad?
Thanks everyone!
Thanks everyone!
