SailCat
- Aug 13, 2008
- 10
Another question on headlights and other plastic light lenses. I have read a lot of posts on wet sanding and the various grades of paper needed for the job but I must have missed how they are used. I have a brand new 3/8 VS reversible, high speed, HD, Porter Cable drill. It is A/C. Also have a 1200 watt inverter that powers it easily.
Is hand sanding or using a drill or polisher the way to go?
What sort of lubricant (if any) do you add to the water?
What type AND size of backing plate or hand block for each? It would have to be soft?
I have one kit with Red, gray, and white "scuff pads". Any good?
Where does one buy 1500-2500 grit cut in disks with Velcro backing?
Or dump the wet sand and use various polishes? Which ones?
Thanks as usual,
Jay (Thinking this newby has an awful lot of questions)
Thanks as usual,
