Does the gel-coat have metallic flake in it?
If it does, is the surface so weathered you can actually feel the flake? (a very rough feel)
Here's my take...
I've seen so many people join this forum and MeguiarsOnline.com, (I used to run that forum), with a boat like yours and the problems was the clear layer over the large metallic flake was so deteriorated that you could see and FEEL the flake.
When a finish like this gets to the point you can feel the flake there's no fixing it.
In fact - In your other thread about improving gel-coat, in my post I asked,
You can see that post here,
http://www.autogeekonline.net/forum...ing/107816-improving-gelcoat.html#post1464642
So I've been there and done that and here's my advice...
Don't wetsand it and make the top clear layer any thinner than you have to or you'll accelerate the deterioration of the finish.
Your boat, your call but once it goes bad there's no fixing it outside of a complete strip and either re-gel-coat or paint over the gel-coat and that will likely lead to stress cracks in the paint job and delamination as the boat flexes in use.
:dunno:
And Mike, the reason I reposted in Detailing 101 was because I wasn't getting many responses so I assumed more people would see it here.
