Theraven
- Nov 25, 2012
- 110
Tips for Wetsanding gelcoat/boats by hand, I have a standard 3m rubber sanding block, and a foam sanding pad. What pressure, direction/motion, when to stop/what to look for, where not to sand and when to change the paper? I know to keep spraying water with a little soap, and to rinse or clean between grits to avoid tracers left behind. Experimenting on an extra panel I used the rubber block with just a plain sheet of s paper, after a pass or two it would stop gliding and stay in place like a suction cup. I cut a thin sponge to fit the bottom of the block, wrapped the paper tight around it and it now glides smoothly a lot longer! Not problems with the sanding pad. Also if I stated at 1000, Would you jump to 1500 or 2000, any general rule about that. In general, could be many factors but is it usually better to start off with an finer grit and move up or down depending on the surface outcome or just use a fine grit even if it takes longer. Thanks you for anyone who responses, in advance. I know there's a lot of questions but and help would be great!!!
