Widowmaker[X]
- Apr 18, 2012
- 7
Hey guys,
I'm attempting to remove swirls on my bright red '06 Mustang, but unfortunately I'm not seeming to have much luck at all.
I'm using a PC7424XP. I started out with PB SSR1 on an LC white pad, which failed to remove much at all. I bumped up to SSR 2.5 on an LC white, then an LC orange pad, and all that seemed to do was leave me with even more swirls, even after following up with the SSR1 again. It's bumming me out!
Sample pic, after SSR 2.5 then SSR1...
As a comparison, here is a panel that I did not touch...
If anything, I feel as though I made things worse!
I washed, dried, and clayed before attempting the polish. I'm set on speed 5 on my PC as recommended, and I timed myself at about 3-4 minutes of polishing before removing. The polish starts to powder a bit (which I assume means it's breaking down?)
I'm using (what I consider) moderate pressure (the pad is rotating slowly, maybe 2 RPM's per second visually). I'm keeping my pads as clean as possible (using a terry towel). I am working outside, but I don't feel as though that should affect the results this much...
So what am I doing wrong here? Any help is greatly appreciated!
