What are the best pads you use with a rotary?
zckid
Hi folks
I’d like to know what pads you prefer to use on rotary for finishing or jewelling?
(The CCS or flat or Kompressor pads or any other...)
Also, is the LC foamed wool pad better than the orange foam pad for cutting? Does the wool provide a better finish than the orange foam? (I mean less haze, less holograms and buffer swirls)
Your advice very much appreciated.
Thanks
zaid
i love the 5.5" flat pads for my rotary they work awesome.for colors i just use orange,white,gray just got a couple red pads for jeweling/waxing thanks to tundra_10 havent used them yet... the lc foamed wool has less cut then twisted wool but more cut then an orange pad, so it cuts good but finishes good too, i want to get some really bad. foam will always provide a better finish vs a wool pad. orange pads can give you haze and holograms but there really easy to remove. heres some links i use often when im looking for pads, they should give you some good information to make good decisions
first one is from fellow forum member CeeDog/corey he makes some awesome product charts and awesome reviews
todd helme from the sister forum autopia made the following one comparint LC pads to meguiars
this one is the one found on the AG webpage.
http://www.auto-geek.net/lakecountrycomparisonchart.htm
Thanks for sharing bro:dblthumb2:
I want to know how the LC wool polishing pad compares with the LC orange or yellow foam pads in their cutting abilities and finish.
Blue 3M waffle pad with Ultrafina for jewelling.
Hi folks
Thanks
zaid
Wonder why the HT Crimson did not make it on the first chart?
I think maybe it wasn't out yet at the time? I believe LC released the cyan and tangerine pads first, and then because there was a demand for a finishing pad to round out the set, released the crimson afterwards.
I use my rotary for over 90% of my polishing. I am very particular about which pads I use. For heavy correction, I use black wool TufBuf pads. For less aggressive polishing, I use the Buff & Shine foam pads. Yellow for correcting and green or white for finessing. I use either 5.5 or 4" sizes. There's way, way too much hype about pads. I've been disappointed with a lot of them that didn't live up to their billing. B & S pads reign as King in my books.
I followed Richy's advice on pad selection and I am glad I did. The Buff n Shines have worked great with my rotary.
