sheeponfire
- Aug 19, 2016
- 2
Do I need to remove the old paint sealant before applying a new layer? If so, are there specific products that will be useful in removing it.
so far my steps for a weekly wash are as follows:
This is my weekly method not including tires and interior. How should this be modified when I apply the sealer? I am looking at doing a a sealant application three times a year.
Also, I have just been using a simple meguiar's quick wax weekly after washing, is the wash and quick wax sufficient between each sealant application or should i be doing more between?
Thank you for your help as I begin my journey.
- foam spray the car and let it sit for 3 minutes
- rinse the foam off with the power washer
- spray one panel again with the foam wash and then wipe in straight lines making sure to rinse my microfiber mitt in the clean bucket with a grate guard.
- dry the panel that was just washed and move to the next until the car is finished and all water is dried off especially since the power washer can get other previously cleaned panels wet
- apply a quick wax spray and wipe it clean
