z06meister
- Jan 28, 2008
- 14
What are your thoughts on wet sanding factory paint? I know it can be done but you need to be very careful since factory cc is very thin yada yada yada.
What I am interested in discussing is... Do you think all the protection and/or UV protection is in the outer most layer?
I have talked to a few body men painters including my brother who is a painter for a living and he has also gone to a few classes and talked to a few paint reps and they all say that if you do not have to break the outer shell of the paint, hence, wet sand you should not do it because this outer layer has the most protection in it and the car will be more susceptible to bird bombs, acid rain etching and possibly even fading. Most will say if it is a garage queen or show car you are usually OK.
What are your thoughts?
I have done quite a few cars and have never had a problem or seen any type of cc failure due to this but do suspect that there is some truth to what the painters are saying.
Of course on repaints where the painter is expecting to cut the paint in order to provide a 100% smooth finish they usually lay down extra cc which is fine. It is the factory paint that is questionable.
There is also a company in Calif that does nothing but this, I am sure some of you have heard of them, glossycar. It seems they have no issues either.
A painting forum would probably be a better place for this discussion but I do not know of any.
