808_detail_nut
- Apr 2, 2014
- 557
I figure I put this in this section so get mikes thoughts on it because I know that you have come across this at some point. Anyway here the situation, I have a new 2016 honda pilot come to me with little white spot all over. The owner says that she noticed it after her neighbor (she lives in a town home area so she shares a parking lot) was trying to remove oil from his spot with biodegradable clay.
Thinking it was maybe just clay I figure try a little APC and pressure wash it off and I got nothing. Then I tried degreaser, tarminator, xenit, body solvent, alcohol, goo gone, wd40,lacquer thinner (not on the trim) and got nowhere. So I was like ok, clay it is.
After doing a foam bath with CG Maxi Suds II and wash I went on to clay with the Nanoskin Fine autoscrub pad with the PC to see if that would work. I got nothing from that at all. Then moved to the medium, same result. Finally I went to the claymagic medium grade and after hours of working the paint I finally made progress removing the overspray (I felt like I pitched a 15 inning baseball game).
I went on and did the same for the windows and now I am stuck with overspray on the trim. I tried the same stuff I used on the paint other than the wd40, goo gone and LT and got nothing. I also tried steam and a scrub brush and got nothing.
Does anyone have anything I can do to get this stuff off the trim? I'm open to trying anything. Thanks and ill get some pictures up tomorrow.
