When do you want to coat it / to have it coated? What climate do you live in? How much are you using this car (daily driver / weekend only)? Do you want to do this DIY or will you have it done for you? Do you have a garage? Do you have a machine polisher and experience with polishing/detailing?I have a 7 day old ‘18 Orange Fury Metallic Mustang I want to get a coating on but not sure what is best and best for first timer
Unless your garage is fully heated, and because you're living in a fairly cold climate, I'd recommend you to wait with the application of any ceramic coating until at least April or early May. Then it will be warm enough to apply CQUK without the risk of running into problems. However, if you can wait until end of May or June (or if your garage is heated), you will be able to apply practically any other coating, including regular CQuartz, Gyeon MOHS, etc. I'd recommend the latter two, as 1. they are fairly easy to apply, 2. have a great shine, 3. are reasonably priced. With MOHS you can expect better up-front results (including shine and beading), but faster degradation, and CQuartz will provide you with somewhat less (but still "insane") shine, but it will hold up better against time.I want to coat it soon, I live in Illinois, it is a daily driver, I have a garage, I have experience with DA polishers
IMHO anything that comes in a spray bottle is not a true ceramic coating, but more of a sealant, regardless of containing some amount of SiO2 or similar substance. Don't get me wrong - they work fine, but you can't expect neither durability nor the physical protection from them, that a true ceramic coating, like CarPro CQuartz, Gyeon MOHS, Gtechniq Exo or Sonax CC, can offer. They (ie. spray SiO2 sealants/coatings) provide a great shine, some chemical resistance and a fair amount of water repellency - but most of their properties diminish fairly quickly, and they do not last beyond a few months. They're however easier and faster to apply, and require less preparation, than true ceramic coatings.McKees 37 paint coating seems to be a great choice for us first timers.
IMHO anything that comes in a spray bottle is not a true ceramic coating, but more of a sealant, regardless of containing some amount of SiO2 or similar substance. Don't get me wrong - they work fine, but you can't expect neither durability nor the physical protection from them, what a true ceramic coating, like CarPro CQuartz, Gyeon MOHS, Gtechniq Exo or Sonax CC, can offer. They (ie. spray SiO2 sealants/coatings) provide a great shine, some chemical resistance and a fair amount of water repellency - but most of their properties diminish fairly quickly, and they do not last beyond a few months. They're however easier and faster to apply, and require less preparation, than true ceramic coatings.
It unavoidably has to, because to achieve a certain layer thickness when applying, the product has to have a specific density/thickness. If it's too thin, it will spread out too much, and you will need to apply dozens of layers (if that's possible at all, because the solvent might just dissolve the previous coats, when applying the new one, or reject the latter, if it has already cured) to achieve the same thickness, that you can get from a thicker solution at first application. However, if a solution is too thick, it will not be sprayable and atomizable efficiently - so it can't come in a spray bottle. That's why true ceramic coatings are coming in drop bottles, not spray bottles.IMHO the method which a coating is delivered has nothing to do with how good it is.
Have you used it?
IMHO the method which a coating is delivered has nothing to do with how good it is. Take the cloth one used to spread McKee’s and look at it the next day. It’s hard. Just like when you do the same with CQuartz. They claim 2 year durability and I have no reason to doubt that.
