What Color Pad?
rouxster
What color Lake Country pad should I use to apply my Klasse AIO and Sealant?
Using it as a light polish? Green
I typically use black to do all my waxing or sealing since I don't one step my own car and I don't use Klasse as a AIO on friends cars.
So,
Green if used as a AIO (very very light defect removal)
If not:
Black, blue, red, or gold (if just using as protection)
I always apply the Klasse twins by hand, I find it much easier but if you think the paint needs a good cleaning, after clay barring, using a machine like the Griot's 6", is a good way to go. Applying something afterwards is a good idea as KAIO is more of a cleaner, thus not having a whole lot of protection in the mix, it is an "all in one" afterall.
When applying by hand I keep the applicator damp always, having a bowl of water handy w/ me, this goes for KAIO as well as KSG. KSG needs to be applied thinnly and wiped off right away. It may not look like your applying KSG but trust me, its going on. KAIO on the other hand doesn't need to be applied as thinnly but depending upon the size of the car and/or panel, when using KAIO, pour out an amount between the size of a nickle or quarter, you'll get a better feel for it once you start using it.
Btw, KAIO is GREAT to use on glass too!
This is from someone who knows a lot about Klasse products. If you want, search his posts for a wealth of information about applying any of their products!
I have used it with a white pad on my first attempt and it worked pretty well. The hand application worked much better though.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
