Hey Everyone,
Last week I posted about starting to polish my 2003 Mustang Cobra http://www.autogeekonline.net/forum...l-started-polishing-didn-t-check-weather.html It had rained several times over the weekend.
Today was my day off and it was clear and sunny out. I decided to wash my car and see if I could continue my polishing. I saw something weird on the wing of the Cobra and thought it was just residue from the weekend rains.
I sprayed the car down and it was still on the car. I then sprayed P21S TAW over the entire car and used a microfiber mit to wash it off. I rinsed the car, and then foamed it with my foam cannon and pressure washer. I followed that up with a two bucket wash. This is what I was left with on the wing after using an Ultimate Guzzler to dry off the wing and trunk.
I thought it was residual oil from the Menzerna 85rd, but I actually had used IPA to wipe down prior to the rains arrival last Thursday. If it was oil, the TAW should have taken care of that. I rubbed a finger across it, and it felt smooth.
Next up was using a clay bar to see if it would remove it. No change. I broke out my Flex and used a Tangerine pad and Power Finish. Again, no change. Alright, I need to big guns. I tried Cyan, and Powergloss. Didn't even touch it.
Ok, what to do, what to do. I got my Porter Cable 7424 and Meguiar's 3" backing plate, and then used the 3000 grit Unigrit Finishing pad. I got my bottle of water and lightly sprayed the wing. Gave the pad a spritz, and started damp sanding. I did two passes, and wiped off the slurry. It really didn't help. I was at a loss, so I figured I should try the 1000 grit. This seemed to work, but didn't get it all. I was running out of daylight. I took out the sanding marks with SIP and Power Finish. The marks towards the front of the wing were not completely taken care of.
I will post pics tomorrow.
I really have no idea what this could be. I polished both the trunk and wing last week, and there were no marks on the trunk. Only the wing had these weird marks. Plus, when I ran a finger over it the paint was smooth.
Don
Don
