No background on anything and you expect someone to know what you did wrong....
Well, it's a little hard to tell from the picture. Does it feel smooth? Is it dull because you dry-sprayed? If it's rough and dry you'll need to sand and polish it. If it's real smooth...isn't the matte look in?
That looks like you held the sprayer way too far away from the hood and the result was a bunch of overspray.
Unless I read it wrong you wet sanded the base coat before spraying the clear. Uh......that's your problem right there.
Don
yea i agree with the above ^^ ive never heard of someone doing that...
Oops, are you suppose to spray clear over the base and then sand the clear?
That's the way they do it at the factory, I'm not sure there's a problem with you sanding the rattle can base--I mean, it wasn't specifically basecoat, was it? It was just a can of Duplicolor touchup, right? I don't think they require that you top that with clear.
I putting the can 4-5 inches away this time (instead of the recommedned 8-10), and it seems to be making it glossy, although it got dark out before I could finish.
Well, at least you'll have plenty of clear on there to sand.
What do I sand the clear with 2000? Sanding won't dull it at all?
Or should I just polish it?
