I'm the sort who frets when I don't have everything under control or have a lot in front of me, especially when it comes to my normally well organised garage and the things that go in it. Having just got on top of the first lot of parts but still needing to find a home for it all, the bomb site I created yesterday with the second load made it feel like I'd lost control. So, as you can imagine, I was quite keen to sort out some of the chaotic mess and reclaim my garage.
Because there was soooo much small stuff in this lot, I went out and bought more carboard boxes and parts trays first thing. That meant no double handling, simply a case of picking something up, identifying it, then putting it into the appropriate box or tray. This also needed to be balanced with what I had already sorted through last week, some of which has already been cataloged. That meant having a separate box for those items, basically a temporary measure until they have been logged.
I needed to be somewhat ruthless here, there was just so much random and unlabeled crap that would never be of any use...............it had to go. I ended up filling a large box with stuff to throw out, which included the following -
- While I saved some of the labeled stuff, I threw out thousands of lose/unlabeled paper gaskets and carb diaphragms. With how cheap that stuff is new, and the fact its actually labeled, there was no reason to keep this stuff. Most of it was for small 2-stroke equipment that's long since been thrown in the tip (Talon, Homelite sh.t).
- Random brackets, again not labeled or having a part number.
- Plastic air filter cover for what I think was one of those crappy rebranded Victa trimmers.
- Random electrical wires and connections.
- An old and cracked SupaSwift catcher.
- Plastic tubes from an unknown blower/vac.
- A bunch of corroded, rusty and water damaged height adjuster plates, axles and bearings.
- Two gasket/breather kits for the Victa V40 engine. Victa used that engine on a price-point mower in the mid 2000's, which was basically another generic Chonda. I have no intention of buying a mower with that engine, and I suspect no one is repairing such a thing now. Out they went.
- Old/aged fuel system parts.
- Flexible drive shafts for trimmers. Those can be costly to buy, to the point where a new machine is often the better financial solution, but again, they weren't labeled.
- Two steel mulch plugs that I simply cannot find what they are for. They are labeled but the numbers don't register. No point in keeping them, which is shame because they are very well made.
With the sorting complete, it was then a matter of finding a home for the blue parts bins. All of this is what I've determined worthy of keeping at home, the rest in cardboard boxes will be put into storage.............for now. Those blue bins are two deep on that shelf.
This one of the boxes that will go into storage. This one has a bunch of throttle controllers and cables, most of which are the
generic curved plastic items fitted to entry Victa's and Bushranger's. However, I did find two Victa Pro-Control throttle levers, which are quite expensive and much nicer to use than the basic ones. Also, a stack of Victa 2-Stroke cables than run inside the intake tube.
This one has a variety of chassis parts, from axles to springs, handlebars to height adjusters.
This one made my day, a Victa Powertorque muffler.
Briggs & Stratton Super Lo-Tone Quantum muffler.
There was also three large ziplock bags full of Victa specific parts, mostly G4 carburettor parts, blade boss hardware, throttle levers and knobs, ignition parts,
spark plug terminals, and the old fashioned
spark plug boots. Then these gems, a bunch of vintage fuel caps, of which I was needing for my little 18 Special. Not valuable but nice to see.
There is a bunch of these, I'm told these are governor vacuum tube pick up points for the G4 carb.
Victa fuel filters................
That's on top of two trays full of blades, bolts and bushings. Some much needed Rover axle bushings, and two large assorted hardware bins.
I've still a bit to do, and that's before I start trying to sell some it. But I'm also feeling more in control of the situation.
