It's not dry, it's lubricated with rinseless wash. You guys should listen to yourselves, one of the posters in this thread says he does two different presoaks before he washes...why not three? Or four?
In the old days I would only do rinseless during the winter when it was just above freezing and using a hose was impractical and would leave too much water on the driveway which would freeze later. I used to use the pump-up sprayer and go around the car to spray the salt and crap off the side of the car...the only thing was nothing would really come off. A pressure washer or a sharp stream from a hose is a different story, and I'm sure you can rinse off some dust or pollen with a pump-up sprayer.
Maybe this is heresy, but if I drive my car stuff is going to happen. I'm going to get rock chips, bird crap, the car is going to get dirty and then have to be washed. The only way I'm going to keep it perfect is keeping it in the garage...and even then I had an electrician knock something over into it, and I had a jack handle fall over and hit it.
So I'm going to wash it in a way that makes sense to me, because even if I do 4 presoaks I'm probably going to mar it in some microscopic amount because it has dirt on it and I'm going to be rubbing things against it to clean it. I'm not convinced that pre-soaking helps any...it seems like it should but my experience is that it doesn't. I decided a long time ago that actually trying to keep my car perfect was going to put me in a mental institution or on suicide watch, so I do the best I can and try not to go too crazy...and I don't have a black car.
And don't worry about disrespecting me, I'm not sure I have done anything to garner your respect other than post a lot of nonsense on this forum which is probably all wrong, anyway. I just listened to an Optimum podcast yesterday that said if you wash ur MF's in water over 140F it will fuse your towels. Then I researched how hot an electric dryer gets and it can get up to 400F or something, and since I always wash my MF's on hot and dry on high, my towels are all fused anyway, and now I know why I can't walk in my polyester leisure suit anymore because it's all fused together. So don't listen to me.
