CG citrus wash
+1 for Citrus wash and Clear
Citrus Wash and Clear is made not to strip LSP's
product description from another site said:"One of our most versatile shampoos that can strip off previous coats of protection or maintain it depending on dilution"
If you're polishing/compounding you don't need to remove wax/sealants as these will remove any protection you have on the car. A paint cleaner, P21S TAW, or CG Citrus Wash should suffice for what you are looking for.
Not true, Citrus Wash and Clear is dependent on dilution, and IMO if it can, it does. I do not use Citrus Wash and Clear unless I am intending to strip LSP. Note the quote below:
Maybe you don't need to, but IMO it is a good idea. If you remove the wax by polishing, all the wax that is removed, builds up in your polishing/compound pad. Which is both a hindrance to cutting ability (a clogged pad doesn't cut well), and wax is more difficult to clean from the foam than polish (making cleaning on the fly more difficult). Though it is not necessary to remove LSP's before polishing, it is a best practice to do so. :dblthumb2:
I don't want this to turn into a fight and get off topic, but I know exactly where you got the info you quoted above and while it is true why recommend a product that wasn't created for that purpose? This is a direct quote from the true manufacturers page, not a resellers "A hybrid formulation from our Citrus Wash and Gloss, Citrus Wash Clear is formulated and pH Neutral for extreme hyper sudzzzzzing action that is 100% safe for all waxes and sealed surfaces." That's like me saying I'm going to use a bottle of Pinnacle Soap to remove protection, because at high concentrations most soaps will remove wax/sealants. Also, I agree with you on the removal and that is why is suggested other products that will remove protection. It really isn't necessary though as a layer of wax, in my experience isn't going to gunk up a pad. Let me know what protection you're using as I'd love to try it out.
If nothing else, just for the beading/sheeting ability that lasted, for me, longer than I wanted to wait before reapplying.
So in all reality a good wash with a dish soap would strip the LSP and a good claying so I could start over on my pickup to buff out some of the swirls and scratches and do a basis 3 step process. Right???
