Whitethunder46
- Oct 30, 2006
- 1,594
I'm trying to figure out what extension cord I need to get. I definately need a 100 footer, but they can get expensive.
It's either between a 14 gauge, which is 15 Amps up to 50 ft, and 13 amps to 100 ft, or a 12 gauge which is 15 amps all the way to 100 ft. All cords are 125 volts.
The only three machines that I'll be running are a PC 7424 which is rated at 3.7 Amps and it's an HD, so it has a 25 ft. 16 guage cord built in.
Also will be running a Rigid 4 gal., 5HP wet/vac which was rated at 9.0 Amps, 120 volts.
And a 1400PSI Karcher pressure washer. 120volts/60 HZ. I can't find the amp rating for the life of me.
Only one machine will be plugged in and running at a time, so should a 14 gauge extension cord be fine? There's a $20 difference between a 14 and a 12 gauge cord, so hoepfully the 14 gauge should be good. Any thoughts?
