Scoobertin
- Dec 4, 2015
- 135
You guys are correct, too much heat but how? I have a GG6 and use 7 pads for my vehicle, so it is not like I am using one pad for the whole vehicle. I am doing some correction on my malibu and checked the heat in the middle. Very hot, I can not hold my finger on there. So after about two sections with 4 passes per section, I have to remove pad and let it cool down. What a pain. I was noticing my first hydrotech cyan pad sinking in the middle so that is when I decided to check and remove for cool down from that point on. The heat is being generated by the GG6 and transferring to the pad. After a while the GG6 gets heat soaked in the middle where the pad gets screwed in and I have to let the gg6 cool so the transfer does not happen as quick.
Is it possible gg6 is faulty and overheating. I keep my hands clear of any vents.
Changing the pads with my GG6 helps a little, but the machine still needs a cool-down due to the heat it generates on its own.
My extension cord is heavy duty and the same that I used with my PC7424 for 10 years without ever having a heat issue.
You sure it's not the other way around with the heat being transferred to the machine from the pad?
Very sure. The heat is being transferred from the gg6. It is isolated where the backing plate screws in. The heat is traveling through the metal. If it were the other way around the whole pad would be hot and not just in the middle portion where it starts. I have the hd model, no extension cord.
