swanicyouth
- Mar 3, 2011
- 9,388
So, a lot of us are using the MTM Hydro Foamer.
After about a year or so, I took mine apart to clean it. It was pretty clean, then I put it back together. When I put it back together, I applied Teflon tape to all the threads and torqued everything down tightly. I did this because the connection above the bottle head (not the plastic bottle) always seems to come "loose".
I'm talking about the threads at the end of the pick here:
You can see the Teflon tape peeking out at the end of the pick - those threads.
Then I put it all back together, everything very tight. So, yesterday I went to use it. Right away - no soap. It would not eject any soap at all. I figured I messed it up somehow when I took it apart. But I thought about it and realized I put it all back together exactly as it came apart.
The only real difference I could think of is the threads identified were now very tight. So I loosened them. I had soap. I found that this must be how the foamer intakes air.
But, what was was interesting was, I found the MORE I loosened them, the thicker and clinger the foam became. I was always actually tightening these up with my hand. I could actually move the threads while spraying foam and it was making a big difference in the "clinginess" and thickness of the foam.
I guess this is another hidden adjustment, at least I didn't know about it. Anyway, with those threads fairly loose, or "adjusted" while spraying, I was able to get foam that was thicker and clung to the surface better than I have ever before.
I was aware of the other two adjustments (black plastic knob on top controls amount of soap and black plastic cone on front controls spray pattern). But, this adjustment seems to control the AMOUNT OF AIR allowed in the foam mixture.
Maybe I'm the only one that didn't know this, but I suspect this may be the cause of the occasional poor performance reported by the MTM or someone whose MTM seems to be "not what it used to be".
BTW I'm using about 3oz of Maxi Suds II exclusively pretty much as my soap and it just seems to work very well. I've have a bottle of the DP, but like MSII much better.
