Elliot@Autogeek
- Apr 24, 2017
- 362
*15% Off Coupon Code COAT15 valid on in stock items. Not applicable on previously placed orders, custom or special order items, extractors, air compressors, BUY ONE GET ONE, VIP Special, car covers, polishers & polisher kits, vacuums, Kreepstool, FlatStoppers, Shop Air Heavy Duty Drum Fans, vapor steamers, garage flooring, gift certificates, bulk and case pricing, complete wash systems or any item as noted on product page. One coupon code per order.
*Free Shipping applies to orders over $95 with ground service within the 48 contiguous United States. Regular shipping charges apply to garage flooring and mats, air compressors, Race Ramps, carpet extractors and any other items that have additional shipping costs as noted on those products. Regular expedited charges apply.
*Free Autogeek Gift Certificates will be emailed to the address used when the order containing the BLACKFIRE Pro Ceramic Coating Complete Kit is placed approximately 48 hours after purchase. One free gift certificate per order.
Paint Coatings - What Are They?
[TABLE="class: Column-1"]
[TR]
[TD="align: center"][/TD]
[/TR]
[/TABLE]
The last couple years have seen a lot of advancements made in surface care technology. Almost every car care manufacturer has introduced or will be introducing a permanent or semi permanent paint coating. Paint coatings provide far greater protection than a conventional car wax or paint sealant, making them an excellent alternative to those who don’t want to regularly apply a car wax or paint sealant.
While a conventional car wax or paint sealant wears off after a couple months, a paint coating forms a much stronger, harder bond that can withstand the elements to a much greater degree. All paint coatings, and especially BLACKFIRE Pro Ceramic Paint Coating, are resistant to alkaline cleaners, road salt, degreasers and other harsh chemicals that can find their way onto your vehicle’s delicate finish.
Paint coatings offer a significant advantage over a conventional car wax or paint sealant in the way that they keep your paint noticeably cleaner in between regular washes.
Paint coatings create a greater amount of surface tension and produce what is known as a sheeting effect. Sheeting water off the surface reduces the chance of water spots from occurring. The secret to these high-tech paint, glass, trim and wheel coatings lies within advanced chemistry. BLACKFIRE Pro Ceramic Paint Coating is ceramic-based and offers a longevity of up to 2 years!
BLACKFIRE Pro Ceramic Coating bridges the gap between entry level commercial ceramic coatings and professional-only industrial ceramic coatings, allowing everyone to achieve an extraordinary mirror-like shine! BLACKFIRE Pro Ceramic Coating was designed using a solvent and fluorine free formula to maximize its user-safety and ensure that it can be applied anywhere. The incredible structural integrity of this matrix makes BLACKFIRE Pro Ceramic Coating one of the most abrasion and corrosion resistant ceramic coatings on the market today!
If necessary, use BLACKFIRE Compound and BLACKFIRE Polish to remove swirls and scratches from your paint's surface. If paint correction is necessary, you can use BLACKFIRE Prep Spray to prep the surface for proper bonding.
If your vehicle does not have any major imperfections, BLACKFIRE Pro Primer Polish can be used to remove light swirls and scratches as well as prep the surface for the application of BLACKFIRE Pro Ceramic Coating.
Shake well before use
_
_
Wrap a suede towel around a foam applicator block and apply a straight line of product onto the towel.
Working in a 3’ x 3’ section, apply the product to the paint in straight lines with a 50% overlap between strokes. Allow BLACKFIRE Pro Ceramic Coating to flash then gently buff the surface with a soft, dry microfiber towel. Switch to a clean side of the towel frequently to avoid streaking.
If you would like to apply a second coat, you may do so immediately after the first. Allow this product to cure for 12 hours before exposure to moisture. Avoid washing your vehicle for 72 hours after application.
And that's it! You'll have ceramic coated paint for up to 2 years!
BLACKFIRE Pro Ceramic Coating Complete Kit Free $10 Autogeek Gift Certificate!
Our Price: $177.91
Sale price: $139.99
BLACKFIRE Pro Ceramic Coating Kit Free Bonus!
Our Price: $78.97
Sale price: $69.99
Our Price: $64.99
BLACKFIRE Pro Detailers Choice Car Care Products, Midnight Sun Car Wax, black fire car wax
