I want to put megs liq cleaner wax over white diamond black pearl.
FWIW I don't think that White Diamond Black Pearl is even an AIO, contrary to the label saying "...is a polymer that cleans, polishes and protects..." every description I have read leads me to believe that the product is a pure synthetic sealant with no cleaning ability. I may be wrong though.
Hey Cara, check out this article: The Difference Between a Cleaner/Wax and a Finishing Wax. Also, I don't see why you couldn't use a cleaner wax over a glaze, but I don't think it would do any good. A glaze is going to fill, while a cleaner wax will clean the paint. IMO, the cleaner wax will probably remove the glaze. I'm not 100% sure on that though, hopefully others will chime in.
Shane's right, using a cleaner wax after an AIO (or after a glaze) will remove whatever protection was left by the AIO (or remove fillers left by the glaze). So Megs Cleaner Wax won't necessarily go "over" White Diamond Black Pearl, but instead will clean it off the paint. Unless your intention is to remove the white diamond black pearl and apply a different LSP I wouldn't recommend doing this. This would be "working backwards".
