What pads do you like on a 75mm mini polisher?
SWETM
Just ordered a 75mm mini polisher this friday. So wondering what pads you like on them. I ordered some foam medium cutting pads and foam finishing pads. Was thinking if you like mf cutting pads or foam woll cutting pads or even a harder foam cutting pads? If you have different brands of them would be awesome also.
Maybe I need to have a medium polishing pad too in the setup? And recommendations would be helpfull. And do you like the higher profile like rupes foam pads or like the Lake Country thinpro pad?
Any insights are welcome and thanks in advanced!
Tony
I have Scholl Concepts 3” pads, Rupes 4” and CarPro 3”, the Rupes are thicker and larger however rotate better contrary to normal thinking. The CarPro’s are not bad either.
Edited to add: I also use Cyclo pads which are alittle larger successfully.
