CAdetailer
- Jul 4, 2012
- 22
Hi Mike,
I am looking for some advice on what polishers to buy/use.
I used to detail back in the stone age (before DAs), using a rotary with a wool pad, hand polish, and hand wax. I would like to get set back up to do my own cars so I have been educating myself on the different polishers & pads that are on the market today. After doing some research I have a few questions on what polisher to buy/use for my personal cars.
1) How do these two machines compare when it comes to heavy/medium correction?:
A) PC7424XP with the Meguires DA MF correction system
B) Flex 3401
2) From what I've seen it seems like the PC7424XP takes more time & finessing for heavier correction even with the Megs DA MF correction than the Flex 3401, what is your opinion?
3) Is there an upper limit on the PC7424XP's ability to do heavy correction?
4) Does one machine work better for a wider range of duties from heavy correction to jeweling or are they about the same?.
5) What is a more versatile combination of polishers:
A) Makita 9227C rotary & a PC7424XP
B) Flex 3401
Thank You
http://www.autogeek.net/flex-orbital-polisher.html
B) Flex 3401
B) Flex 3401
Thank You
