Thinking about getting myself one. I saw a Yahama Powerstroke 3100psi the other day in Costco. I wouldn't mind trying out a foam cannon. Are there any specs to take into consideration for foam cannons ?
I have a cheezy Ryobi. Does what I need it to do.
^^^Not too bad of a deal (and CostcoThinking about getting myself one.
has a nearly unmatchable return policy);
but I prefer pressure washers that come
with Honda engines.
As a hobbyist I use the cordless spx6001c. Up here in the Northeast all outdoor water lines are turned off in winter so when we get above freezing I wheel this out and wash 2 cars on one battery charge no problem. When the weather warms And the water is turned on the Sunjoe is used as a final rinse in which I have 1/2 filled the tank with DI water. Can also wheel it on to the dock to wash the boat
So i picked this up 2.4gpm 3100psi Yamaha Powerstroke gas powered pressure washer last night. It seems to me, that its probably too powerful for using as a foam cannon / cleaning cars. Which is fine cos i do have a lot of other uses for it.. I didn't buy it for cleaning my car, but it would be nice if i could use it for doing so....Anyway according to the documentation, even the white 40degrees nozzle doesn't have a car listed as a recommendation. Lawn equipment, RV and boats are listed to be used. I don't know of a way to dumb down the PSI other than nozzles. Are there any other nozzles out there, that'll bring it down to less pressure so that it'll be more suited to an automobile??
What did you spend if you don’t mind my asking
