What product for pedals?
conman1395
Do you guys use anything for your cars pedals (gas and brake)? I'm assuming something like 303 Aerospace would make them too slick.
Clean with APC; and let them be...
I don't trust any dressing, and don't want to make a mistake and then have to try and strip it off and create more work.
Indeed. I clean them with a good APC and let them be.
I use an APC but add BlackFire interior protectant. It's non-greasy, not glossy if you apply light, but makes wiping dust off easier in the future. I see others advise nothing and I don't blame them - anything which could cause slip would be catastrophic but the BF stuff works perfect.
Use your favorite cleaner & let it ride.
Same goes for motorcycle floorboards , hand grips & tires.
SR66:dblthumb2:
From my experience I have seen apc leave the pedals kind of slickish therefore I have found that window cleaner does a better job at cleaning them just be sure to dry them throughly
I use D120 glass cleaner on mine. But mine are metal with rubber "dot" grips. Glass cleaner will work on all plastic ones but I will sometimes use an APC or a WW/QD type product for weekly wipe downs.
Griot's Interior Cleaner works well using a detail brush , that should get them really clean and leave them dark black.
Tornador with apc and a quick wipe
Sent from my LG-E970 using Tapatalk 2
I've used Silk Shine on them for showing to customer after cleaning with APC. Thing is that they don't stay clean at all, so why waste time on dressing them or worrying more past cleaning them.
