Radarryan
- Nov 9, 2012
- 778
I am wondering what product I should use on this textured plastic that would be normally,at least in my view, be found on exterior trim. This plastic, as you can see in the attached photos, are found under the hood (the storage compartment) and the engine cover (under the trunk compartment.)
Since it is textured, I was thinking about using CarPro CQuartz DLux (already own it) on it since it provides a permanent solution (since the hood will cover most of it). Same goes with the engine cover except it is 100% covered.
Please note, part of the plastic under the hood extends outside the hood and would be part of the cowl, however it is all one piece.
Thanks for the feedback/help!
