lalojamesliz
- Oct 11, 2016
- 89
I need to search better.... nevermind guys
As already said, they handle temperatures extremely well. Most of them can be used safely even in the engine bay, where you can have temperatures well over 100 °C / 200 °F. You won't have ever anything just close to that on the outer surface of your car, unless you shove it into an infrared heat curing chamber.I was just wondering if some handle the heat better.
I just ordered a gallon of Optimum Car Wax.... I'll use it like once a month when it gets hot or as needed.
The best I find in hot application because I'm mobile sometimes a garage is not available would be gtech serum or mc kees 37 coating.I need to search better.... nevermind guys![]()
Thought you meant what's the easiest to apply in sun.The best I find in hot application because I'm mobile sometimes a garage is not available would be gtech serum or mc kees 37 coating.
