What speed on GG6 for Nanoskin pad?
EKRock2676
I'm new to using a Nanoskin on a DA and I'm going to be using the Nanoskin autoscrub pad for the first time and was looking for some guidance as to what speed I should use. It's the 6 inch pad, fine grade. I'm guessing as slow as possible to start and work my way up to something effective without generating heat. I'm using GG Speedshine and a GG6. Any input would be appreciated. Thanks!
When I used the nanoskin pad on my gg6 I used speed 1. No need for fast speeds.
With the GG6 the 1 or 2 setting shoud work.
All you need is enough speed to maintain light pad rotation. This goes for any DA polisher. You don't want the Nanoskin pad to simply jiggle.
Hey mike while we are on the subject of the nanoskin 6 inch pad.
Is there any difference in the material of the washmitt and the 6 inch DA pad?
The reason i ask is because i bought the washmitt and was wondering if its a problem to use the DA pad by hand in the nanoskin bubble bath too.
Thanks Guys, the GG6 worked best at the number 2 setting with a light touch to keep the pad rotating. It did a great job and was way faster than claying by hand. Ed
