What tape to use?
brentvelo
Just curious as to what tape everyone uses to tape off trim/panels, etc. when polishing? Is the blue 3M "home" tape okay?
I use either the blue or green painters tape, probably 3M...:props:
They will all work, I'm not sure as I haven't compared but I think the Meguiar's tape is a good value and specifically made for car detailing not house painting, I have the reasons why in an article somewhere, let me see if I can find it.
The important thing to remember when taping off a car to detail is to only leave it on long enough to get the job done and then remove it.
I was at a shop in SoCal once where someone had taped-off a car for painting and then for whatever their reasons never removed the tape, moved the car back onto the lot where it baked in the sun... it's going to take a lot of work now to remove all the adhesive that has pretty much become one with the paint.
I tend to use the 3M Painter's Tape in my project just because it provides better contrast than the brown Meguiar's tape. If the Meguiar's tape was a brighter color I would use it more often.
:xyxthumbs:
Here you go... from page 2 of this thread,
Tape it off and avoid a lifetime of ugly...
Mike Phillips said:
I spoke with Mike Pennington, the Director of Training for Meguiar's about some of the cool features for the new Meguiar's Tape and have summarized our conversation below...
The new Meguiar's Masking is really designed to be a great general purpose tape which lends itself well to use in the detailing world.
Product Attributes:
  • Excellent handling
  • Instant adhesion and good holding power
  • Resists curling and lifting
  • Solvent and moisture resistant
  • Ideal for automotive detail application
Normal painter's tape, usually the blue or green tape we commonly see and use when taping-off a car, is a fantastic tape, it is really an overkill from a design perspective for the detailing market.
Normal painter's tape is purposefully constructed for application where a wet edge (critical edge) is present, that is where fresh paint is being applied and for this reason one of its main features is designed to prevent bleed-through. That is to say that painter’s tape is designed so that wet paint won't leak under it at the edges. This is an important feature when applying fresh paint.
When detailing cars, this is an unnecessary feature that affects price. The Meguiar's masking tape is more specific to the needs of detailing, it is safe enough to protect what you want to cover and protect from product residue but not over designed for its intended use. In addition, the Meguiar's tape has much improved adhesion performance over traditional painters tape when exposed to situations where water is present. (For example - Wet sanding)
Note that because Meguiar's tape is not designed for use where a critical edge is a factor, it is not recommended for use as an actual "Painter's Tape".
Painter's Tape and Detailing Masking Tape, different designs for different applications.
Hope this helps...
:xyxthumbs:
Here's what DIDN'T work for me. I bought some super cheap rolls of masking tape at the local hardware store. Soooooo frustrating to use. As soon as you pull off about 2-3 inches of the stuff it just splits and breaks off. I ended up throwing it in the trash.
Basically everything Mike recommends above works. I now use Megs masking tape, blue painters tape, and I've even used green "frog" tape.
I use 3M scotchblue painters tape with edge lock.
I used that last time I worked on my car. I don't know if it was the 90 degree days or the fact that I taped it off the night before, but never again. Nasty adhesive residue got left on all my rubber trim. When I mentioned it here somewhere else, someone replied that it's a common complaint with the edgelock stuff.
I use the green 3M automotive tape. Works great, but I still hate taping.
I think it might of been the heat as that same thing has happened to me before I had a garage to work on. I am sure there are much better tapes out there, but I bought these in a pack and I want to get my moneys worth too!
I recently bought and used Kamikaze’s detail tape.
It’s far and away the best detailing tape I’ve ever used..... bar none.
The drawback is it can be hard to find compared to some of the more readily available ones.
I bought mine from Esoteric Car Care.
You should post your experience on Esoteric Car Care FORUM.
The more experiences HERE the better! No need to run people off because they use ‘competing’ products. Information is power!
Fair enough but I think green tape is the least of the forums worries.
I have seen many more posts about much more expensive products repped by the place mentioned without much fuss...
I guess a rule’s a rule.
