For cutting, is it best to use a meguiars wool pad or lake country yellow pad? Can you use the meguiars wool pad with the meguiars DA. I know meguiars doesn't recommend it but I heard people say its ok to use.
Wool pads are the most abrasive, if you want to cut, I would get the micofiber professional pads by meguiars, red is for cutting and black is for finishing
Wool pads on a rotary
Yellow foam on a dual action machine
Wool pads are really designed for the rotary machine. Lake Country offers a foam-wool pad that appears to have some success on a dual action machine, especially the Flex 3401.
The length of the typical wool pad is long in comparison to the dual action oscillation which is about 3/8" or so. Because of this the wool doesn't lay down as it will with a rotary machine and will sort of jiggle which does nothing at all.
