What went wrong?
Irish
I've been using Klasse AIO for awhile now and I've always had good results. Today I I set out to give my car a fresh coat for winter when this happened:
Pulled it out into the sun to make sure I'd wiped all the residue off. My jaw dropped. I'm at a loss. My hood looks absolutely awful.
Using an LC green, PC on 3.5, CG luber for pad prep. Help!
Are those scratches?
It's hard for me to tell from the pictures, but it almost looks like clearcoat failure.
It looks like the Klasse AIO was not worked in long enough.
Try applying another coat of the Klasse AIO with your PC but try working it in a little longer and at a faster speed like 5 or 6.
What did you use to remove the AIO. Looks like scratches from something in your removal material.
The green pad might have been a bit too much. Give the white a try. Also did you use enough product? Look like marring/pseudo holograming from dry buffing or buffing too long. KAIO is a chemical cleaner so there is no need to "work" the polish in.
Looks like you went to a dry buff with the KAIO. Try applying it by hand to a small section and see how it looks.
Thanks for the feedback guys.
We tried a couple different suggestions, only thing we changed was going with a white pad and using ONR to mist it. Did manage to get the hood fairly cleaned up with m205 on an LC orange. I was freaking out there for a minute.
