If this doesn't "creep you out" you may find some help in here: http://www.autogeekonline.net/forum...eak-open-coating-wax-remove-creeping-out.html
I intend on getting this Glaze/polish for xmas and have heard that it is rather tricky to remove
what would be the best way to apply by hand and how to effectively remove this fantastic product. :buffing:
My experience is that removing of dried on #7 after it is left to soak overnight is far more difficult to remove than wax. It is so difficult to remove that I would not attempt to remove it without at least water, lest I mar my single stage black paint in the process, by rubbing so hard.
Just do small sections and don't let it dry. What is your intention with this product?
It is a pain to remove if dried. Not sure if Mike mentioned this: If you let it on overnight, the best way to remove it is to reapply more #7 then wipe it off. Basically rewetting the dried stuff with fresh product and it makes that process much much easier.
Indeed using more #7 removes dried on #7 well, but nowhere near as well as using water or detail spray. There is no comparison as far as the ease. Unless there is a reason not to use a detail spray or water, I will use water or a detail spray after the water in order to save money on #7, unless I am going to apply more #7. I admit I have left #7 on for days and have been concerned about dust settling into the#7 and possibly marring the finish if I didn't remove it ever so gently. This is how I discovered the effectiveness of waterless wash, then detail spray, then water.
I concur. WW and QDs do remove the oils, however, water doesn't really remove them.It just removed the dried on paste portion. There is still an oily film left on after using water. As long as you are still in the process of applying coats of #7, simply adding more #7 is the best way, particularly if you cover it with saran wrap, to keep out dust. I believe using a plastic cover might also increase the effectiveness of the absorption as well.Very true but if you are really trying to restore SS paint and saturate with 7's oil's, I find using 7 to remove 7 to be the best way. Seems WW's or QD's remove some of the oils IME.
All comes down to personal preference!rops:
My intended use of this product is too fill in any remaining cracks and alleys in the clear coat of my paint to further smooth'n the paintwork to create an even deeper wet look and to provide a smooth surface for easier waxing and I assume a more durable coating of wax due to the ultra smooth surface.
While giving the illusion of great looking paint, the oils actually hinder the bonding capabilities of waxes and sealants on clear coats. Single stage paints are a different animal.
^^^Where in the World did you hear this??^^^
