Clarifying what you mean by One Step would help.
If you're looking for a 1-step polish, depending on many factors, Sonax Perfect Finish, Menzerna PF2500, Ultimate Compound, M205, the SF4000 you already have, all of them used on a polishing pad may give you the 1-step polish reducing or eliminating minor problems while finishing LSP ready. Then you'll have to apply wax, sealant or coating, and that'll be a '2-step' process in my opinion.
Depending on paint hardness, I've managed to use FG400 with orange cutting pad as an 1-step using the 'Smack's Technique'.
If you're looking for 1-step only (from polishing to wax altogether), you can look for XMT360, Blackfire total polish and seal, and many others at AG. Mike Phillips has a great topic demonstrating those All in One (AIO) / Cleaner Waxes in details.
I like XMT360 in fast works because it can get rid of minor defects while leaving a beautiful finish, everything without the need of even buffing at the end (although I always do one or two towel pass anyway).
That would be considered 1-Step in my opinion.
Anyway, I always apply a Carnauba Wax (like liquid Souveran) on top of an AIO because I like the look and smooth feeling, but again, that's 2-step.
About MF discs, if you have a Porter Cable (PC), you'll benefit from using them, mainly if you're looking for better cutting. MF are thinner than foam pads (generally) so they spin better using a PC. They also works well on lower speeds (3-4) and less pressure, so you will not be struggling with pad rotation since those characteristics above are in favor of pad spinning.
I tend to say the pressure used for MF discs is 'FIRM', not Heavy.
Generally, I like to use D300 compound with MF, but you may also use any other product like FG400, Ultimate compound, M105, M101, and many others.
What I see generally is that after cutting with MF and a compound, you'll generally need a secondary polishing / finishing step to achieve flawless finish, and that means getting rid of any 'haze' left by compounding step with Microfiber.
On the other hand, I'm seeing people here using MF FINISHING disc with M205 and achieving awesome results in 1-step polishing.
I'm yet to test this setup (I have both MF finishing and M205), so I cannot give my personal opinion on this one, just comment from what I've read.
I'd recommend you to get a 5" plate to use 5.5" MF discs, since the larger discs will make your PC 'struggle' a bit more to work with such large pads.
Lake Country Hydro-Tech pads in 5.5" are also a great addition to a PC-style machine, since they can be used as 1-step polish and with AIO products. They cut well while finishing really nice (all of them, the Cyan Cutting pad and the Tangerine Polishing Pad).
I've tried using Hybrid Pads (the ones I use with the Flex) with my PC-style machine (a G220v2 from Meg's), but I've found the pads to be much thick and dense for such machines. Sure it will work, but will take more time and work than using a smaller Hydro-Tech like mentioned above.
I've placed a thread here using AIO in a Peugeot where I have a picture of a test spot using 3 kind of pads for XMT360 (White Polishing, HT Tangerine and MF Finishing Disc). I ended up using all 3 pads in different areas, but if I had to chose one, the Hydro-Tech Tangerine would be the one.
Hope I've helped,
Please, feel free to ask if any question left.
Also, feel free to disagree from my point!
Kind Regards.
