Alex Haramic
- Mar 26, 2013
- 156
Looking at electric powered pressure washers. Like to use it for wheels and wheel wells. 1,600-2,000 psi. I feel that's a good amount of pressure not looking for something to powerful. Any suggestions
Do you use a foam cannon with the marcher follow me? I've been thinking if getting the same one but not sure if the cannon will work great with it. What PSI do you run at for general rinsing ?
Sent from my Nexus 6P using Tapatalk
Sunjoe 3000. Bought it last Christmas on sale and got an extended warranty.
It works great..
Where did you get the karcher attachment?The cannon works good with the PW. I get good foam with it.
Use a good foamy soap and play with the dilutions to your liking and make sure you get a cannon that will work with electric pressure washers with a lower PSI. There is a different one for gas pressure washers with higher PSI.
I use it full strength so I assume it's around 1800 psi.
Make sure you get the connection that fits the Karcher.
