Why is my paint yellowing after wet sanding?Feed back please
Mike Phillips said:Something I point out in all my detailing classes on the topic of wetsanding and that is,
So everything is working against you from the very start...
- Sanding removes paint
- Compounding removes paint
- Polishing removes paint
- Paint from the factory is thin
I don't see yellow in your picture.
I "think" I see yellow splotches?
You aren't the only one Mike.
These photos clearly show sanding has gone through the clear and the color revealing a sealant or primer coat.
Gentlemen, confession time. Mike Phillips was correct, that was the red filler primer I sprayed under the base color.
I guess I did not spray enough coats of base color
Please, after reapplying 3-4 coats of base color should I use urethane clear coat instead of the acrylic clear coat I used before for $7.95?
I over used the Maguiar medium cut cleaner along with wet sanding because the spray clear coat had a cloudy look even after buffing.
Here is an example of the types of amazing results you can achieve with 3M's Trizact 1500/3000 disc combo followed by a buff/polish. These are before and after photos of a a black hood that I leveled some orange peel on after a respray...pretty much speaks for itself. If done correctly, the results are simply astonishing.I have been dry sanding since the waterbug. Maybe 14 years ago? typically using a hard 3M stick it 6" pad. I didn't mean to say I felt the interface pad was better, there's no doubt its letting the paper follow highs & lows even more. Its just less dangerous for the average user.
I'm not at all afraid of the standard pad, thats how I cut my teeth dry sanding. The last car I sanded was a driver, I just wanted the peel gone, so interface pad worked ok for that. something different so I thought I would try it I should have worded that better
