Here is some important information to understand when it comes to the factory hardcoat of automotive headlamps:
- All OEM headlamp lenses are required to meet the abrasion and chemical tests cited in the DOT lighting regulations.
- All OEM headlamp lenses follow an SAE standard for a 3 year UV exposure test to ensure sufficient optical characteristics.
- OEM headlamp lenses will have a hardcoat thickness of between 8-18 microns.
- These hardcoats are UV cured in a clean room. They are not a typical spray on clear coat.
- The life of a hardcoat is dependent on a number of variables which include sun exposure, weather exposure, climate region, vehicle usage, vehicle care, etc.
Ceramic coatings are NOT a durable or suitable form of protection for headlamps. Ceramic coatings have a thickness of between
0.5-1.5 microns which is MUCH thinner than a headlamp hardcoat.
For the same reason you wouldn't ceramic coat a base paint layer, is the same reason you wouldn't ceramic coat over bare polycarbonate. Clear coats for paint and hardcoats for lenses are thicker, more durable, more UV resistant and longer lasting.
Does applying a ceramic coating over a
NEW headlamp offer any benefits? Sure. It won't hurt the headlamp but like any top layer protection, its only temporary. I suppose it *could* possibly extend the life of the hardcoat but only if properly maintained and reapplied at specific intervals.
RESTORED headlamp offer any benefits? NO. It will wear away within a short period of time and the lamp will become hazy and deteriorated once again.
Aside from re-spraying headlamp lenses with a commercial grade UV hardcoat, the next best thing is PPF (as already stated multiple times in this thread). But not just any PPF will suffice. It has to be optically clear with a high light transmittance level. Remember, these are your headlamps which are safety devices and you depend on them to provide maximum lighting at night. I have not researched which brands are best for clear PPF. The manufacturer of the film should be able to provide documentation of measured light transmittance level.
