steamshooter
- Jun 7, 2010
- 135
Which way is more thorough using an old towel or using compressed air?
Compressed air with microfiber pads. I like a terry cloth for foam pads.
:iagree:Compressed air with microfiber pads. I like a terry cloth for foam pads.
Some may not consider a pad washer cleaning on the fly but it's the best way to go especially for foam, until you use one you don't know what your missing.
PS I still think they may be the most over priced piece of detailing gear but they do a great job.
I think if your in the business, this is a MUST have. Anyone in the business knows time is money.
Compressed air is a luxury everyone should have, it helps more than words can express. Not only in the cleaning aspect, but in the cooling down of the pad as well. It's a must have for MF pads, and works equally well on foam pads.
What I do with foam pads is to angle the compressed air nozzle so it's almost parallel with the pad, and basically spray sideways. That way, nothing gets pushed into the foam, but rather, gets pushed off. Even a towel I feel pushes some product into the foam if for no other reason then the downward pressure.
I'm curious about the ideal technique for using terry cloth and grabbing the DA's pad. Every time I do it, I feel like I'm just shaking my hand. There's little to no relative movement between the pad and the towel.
I almost feel like doing a single section pass on the towel would be better.
