RUPES Mille Ultra Fine
•Key Features
-Cut Level: 1/10
-Filling Power: 0/10
-Gloss Level: 10/10
•Description:
-RUPES Mille Ultra Fine Gel Compound is
an ultra-fine water-based finishing polish
designed to be used in conjunction with
short-throw gear-driven dual action polishers.
-It works by using precision-milled aluminium
oxide particles to burnish painted surfaces to
perfection. These ultra-fine abrasives cut the
paint back at the finest scale imaginable,
smoothing out micro-defects and creating the
flattest possible finish.
-As a result, light plays over the paint surface
much more evenly, making it look as deep and
glossy as possible. Specially formulated lubricants
maximize its working time, while its filler-free
formula ensures that defect removal is permanent
rather than temporary.
•Specifications:
-Adds Protection: NO
-Chemical Basis: Water-based
-Contains abrasives:
Yes (DIMINISHING)
-Contains Fillers and Glazing Oils: No
-Cut Level: 1
-Gloss Level: 10
-Suitable for Hand Use: No
-Suitable for Machine Use: Yes
-Suitable for Soft Paints: Yes
-Suitable for Hard Paints: Yes
-Suitable for Intermediate Paints: Yes
How To Use:
-RUPES Mille Ultra Fine Gel Compound should
only be applied using the RUPES LK 900E
BigFoot Mille or other gear-driven dual action
polishers.
-For best results, it should be applied to freshly
decontaminated paint using a RUPES Mille Ultra
Fine Foam Polishing Pad (it's not designed to be
used with other types of pads, e.g. wool).
-Only 3-4 pea-sized drops of product are
required per 18" x 18" area,
and these should be worked in thoroughly
at 300-400 revolutions per minute (speed 3-4
on most gear-driven dual action polishers)
until only a hint of residue remains.
This residue should then be buffed off carefully.
____________________________________________
Hope this helps.
