What's wrong with my Sunjoe spx3000
Colehep
Hello thank you for checking this out if you did.
I just put on a brand new 25 foot hose that is made by sunjoe for an extension i just put on my new 100ft hose for the input . the machine keeps having to build up for the water and is not pushing out the pressure it should at all is this because of the extension hose and if so why the hell would they sell it to me lol thank you for all the input
Sent from my Pixel 2 XL using Autogeekonline mobile app
You may need a larger diameter garden hose to supply water to sun joe
This is a problem I had with my standard sun joe with no extra length pressure hose
I will have the check that out its a brank new kink free hose from costco but thank you ill check it out it started to work with a bit of spit back every now in then after about 10 minutes
Maybe it’s some air still in the line. I know when I connect my simple chuck I have to run it for a couple minutes to get all the air out of the line
